Re: diode check
Juice..... Disconnect the diode leads so that the diodes are not connected to anything.<br /><br />Using a ohm meter set to high ohms, connect one meter lead to the diode terminal and the other meter lead to ground. Now reverse the ohm meter leads.<br /><br />On a good diode, you would get a reading in one direction (meter lead hookup) and none in the other (meter leads reversed).
