Mud Puppy
- Sep 8, 2013
- 276
I have a boat trailer manufactured by Dilly Trailers, by Green & Green Mfg. Co., Lancaster, Texas and now defunct. It is a DO-18 Semi V and sets under my old I/O Tri-hull I acquired.
I have found all types of information concerning the location of the keel rollers and just probably haven't stumbled across the right thread yet. I want to apologize for being so wordy, but it to me it is a little complicated and thanks for any input in advance.
My question is about the stern rollers and their orientation. This is the first trailer that I have been around that is completely rollers and no beds at all. I have seen trailers of this type but never paid any attention to detail when the trailer was loaded.
When I got the trailer, the boat was hanging in midair forward the stern rollers a good 4" when the bow was engaged in the keel roller. I don't know if my question is really warranted, but it seemed like a lot of stress being imposed on the hull at the first set of rollers forward the stern rollers and so far away from the transom with the weight of the engine and sterndrive.
I turned the rollers around and moved the boat and readjusted the keel roller. I didn't think the bracket on the stern rollers should be turned out where it might scrape the hull. I know that they should be well under the hull when I trailer the boat and come up under it as I pull out of the water, but this way the bracket bends in towards the front of the trailer.
It appears to be a lot more secure and the weight at the stern is now more evenly displaced under the transom other than just somewhere out on the hull in the middle of nowhere. It may pull a little better than it did with all the weight FWD.
The bow eye and the winch are as close to level as I think it needs to be for now. The wench can come down some, but I haven't changed its position yet. As I get a little further along with the boat restoration I am going to change out the web and may change it then if need be.
Most of the lakes around here have pretty flat ramps that drop off pretty fast in the water except for one or two, so it won't be used for anything more than securing the bow for transport and not for pulling the boat up on the trailer more than a few inches. I also went back and repositioned several of the rollers mid ship and forward which were adjusted incorrectly. I did all of these adjustments on flat and level concrete.
Can someone look over the before and after photos and tell me if I am on the right track or completely off track and possibly make some comments or suggestions please.
before:
You can see by the photos above, the stern rollers weren't supporting anything when the boat was near the keel roller. One good bounce could take out the hydraulic lines for the trim cylinders, or crack the hull, or both.
You can see with the stern being positioned as in the photos above, the bow still needed forward another inch or two to fully engage the keel roller.
after:
I also rotated them slightly so both rubber rollers actually contact the hull and not just the radius of one roller only.
After looking at the photos, I am thinking I need to move the keel roller forward one bolt hole and that will move the stern right over the stern rollers about 1" forward of the transom. I plan to sand blast the trailer this spring and use a good etching primer, followed by a high solids primer if need be, and then a good quality urethane topcoat.
Thanks again for any insight and suggestions.
Mud
before:
after:
Mud
