So far, you fellas have been on the money helping me diagnose and rectify problems thus far...so here's another ? for my '64 40HP Evinrude BIG TWIN.<br /><br />Presently, I'm unable to get the motor to start and idle properly in Neutral.<br /><br />As a background...earlier today, there was no issue at all w/ this...and I made no changes since the time it worked properly, till the way it barely works now.<br /><br />What I did...pulled flywheel to check components. Coils were modern, no cracks, looked OK. Cleaned up the points, though they weren't burnt, just dragged some fine paper through them, and regapped them as suggested to .02. Key wasn't sheared.<br /><br />After reassembly, fired it up just fine on the first pull, and ran it for 10 minutes. Per advice, I used some of that "Sea Foam" (luckily nobody called the fire dept...smokes ahoy!)...I let it sit 5 minutes...pull started again on the first pull, and ran another 10, then repeated the procedure, and ran it again.<br /><br />So all told, I had it running just "fine" for about 25 minutes. It would idle fairly nicely in Neutral.<br /><br />Then, all of a sudden, for no reason as far as anything to do w/ me, it no longer works the same.<br /><br />What's strange, is I can pull start it, and it'll fire up right for a brief second, but even giving it more throttle it just dies...I can repeat that procedure over and over, but I never am successful in getting it to run in N.<br /><br />As an aside...if I catch it quickly enough, I can shift to Forward, give it some throttle, and keep it running in my test bucket fine...but not in N like always before.<br /><br />I'm figuring a carb rebuild is in order anyway, since it's been 3 years since it was last rebuilt, and until a month ago, wasn't used...and the float doesn't shut the valve/gas flow. But, nevertheless, even w/ the incorrectly performing carb, these problems that prevent actual water time use, are new. A month ago, I was tooting along for three hours, w/out a hint of concern...now I'm not so sure.<br /><br />I will rebuild the carb...and see how that affects things...but before spending the time and money, it sure would be nice to have a bit more concrete answer as to why this has all of a sudden gone from working good enough, to barely working at all.<br /><br />Thanks again, for any advice...I've got a relevant manual (Clymers), but it doesn't go into troubleshooting like this.
