Boobie Trap
- Feb 21, 2011
- 122
Volvo 5.0L Gi.
Serial Number: 4012031874
Model Number: 3869057
I am having problems with my STBD engine. When it has been setting for a day or so, it will crank right up. After I get out and on the hook for the afternoon, I have to pulse the throttle in throttle only to get it to start. It does so begrudgingly. When it does start, it kicks out what looks like fuel in the water and gives me the impression that it is flooded. Stands to reason if I am pulsing the throttle, but why does it take being flooded to start?
They both run about 600rpm at idle and when warm about 160+/- a little. After it cranks, it idles and runs just fine. It matches the port side in RPMS up to WOT.
I have been told that it is the fuel pump. I am not that confident that it is the fuel pump if it runs so good after it cranks and it does not do it all the time. Sometimes it will crank right up even when warm. Just baffling and driving me crazy.
I tend to not trust repair shops as they are in business to make money and at over $100 per hour plus service call can run into a lot of money just to diagnose the problem.
Any help would be greatly appreciated!!
