Difference in carbs
Simple_Man
1987 85HP. I have a broken carb. My friend gave me as set. but they are missing the jet on the center post inside. will they still work. See pic my old one is on the left. 20170614_154757.jpg
ThomW
Broken how? A carb will most likely not run correctly if it is missing a jet. They regulate the gas flow to a carb, and without it, it probably won't work...or at least correctly. Why don't you order a replacement jet for the carbs?
Simple_Man
Thom if you look at the pic the one on the left has a jet on the post, the one on the right does not have a place for the jet.The housing at the mounting hole broke.
Jiggz
it could be the jet is located at the bottom of the center post while the old one has its jet on the side. There's no such thing as a carb having no fuel jets, I mean as far as this old carbs are concerned.
jerryjerry05
The jet's in the bowl screw.
​Compare the #s and see if they are the same.
Simple_Man
Great I didn't even notice.the bowl screws.. THANKS GUYS!!!!!!!!
jerryjerry05
The carbs using the bowl screw were used in the early 80's
Measure the venture or throat of the carb.
They must match.
​The bowl jets came in 4 sizes.
Pretty important that they match what you have.
If they came in a set?? Pretty important to use the whole set.
Simple_Man
I am using the whole set. The Throat is the same size. I believe the jets are the same size, and the little tubes in the stem are the same. I'm going to try them today.
Simple_Man
It's running with the WE4 carbs. It needs a few tweeks, but it is running not bad. Thanks again Everyone:joyous:
