difference in carbs, 1995-130 Looper
looper power
I have see several sets of carbs for 90 deg v4 loopers from a 1995-130 around. but I was wondering if the extra idle screw was worth the money to put it on my 1985-140. I do have a set of 6 peddle reeds to go with it
Dhadley
Re: difference in carbs, 1995-130 Looper
What changes performance is the venturi size so a lot depends on the set up. The 85 stuff was a fairly large bore. The newer stuff has different circuits and uses the different airbox. <br /><br />What are you trying to accomplish? A better idle?<br /><br />Dont forget, the carb bodies and throttle bodies are a set as far as style and venturi size. Dont mix 'em up.
