Difference between these plugs
Al-53
I have a 1983 35HP Johnson..I believe it is a ELCTS version...
Now I have QL77JC4 plugs in it...I went to get new plugs at NAPA and they gave me L77JC4 plugs and said these superceded the others...
is there a different performance wise..I know the Q version is surpressor type..but what would the surpressor type be needed for...
and can I use the L77JC4 without a problem
AL
Benny1963
Re: Difference between these plugs
yes you can the q is for resistance if you running gps fishfider radoi then you would want the q
F_R
Actually, the L ***is older than the QL***. The Q stands for an inductive suppressor, not a resistance suppressor. Either one will work, but the Q will give less interference with electronics.
Al-53
Thank you ...I will just pick up the Q version and keep the regulars in the plug case for emergency plugs...
Al
Vic.S
An interesting technical article HERE
Al-53
Thanks Vic..that gave me a better understanding of the types of plugs...I did find the Q version and bought 4 to carry onboard as spares...
AL
