I am currently running a '79 Evinrude 100hp. Although it's old it has been running great, but recently the trim quit working. After taking the motor off and removing the trim unit, I managed to fix it by taking it apart and cleaning it. BUT in order to do this I had to detatch my throttle cables from the engine (to get the engine off without taking off the throttle) Since I've put it back together, I've been having troubles with low running speeds. It runs great at high speeds, but when cruising slowly (trolling speed) it coughs, sneezes and eventually quits. ALSO when I go to switch from forward to reverse or even neutral to forward, it instantly quits unless I have it idling high enough then QUICKLY slam it into forward which causes and pretty rough start. <br /><br />Is this a problem I am having with my carbs running too lean or being too dirty or do you think I have changed my idle speed while playing around with disconnecting the throttle cables from the engine?<br /><br />Let me know, I gotta go out there soon!
