beverly
- Sep 12, 2010
- 58
I have a (new) 1982 Evinrude 8Hp and considering buy and repairing my other prop.
As for buying one. theres different brands which gets confusing for a newb
Solas Amita 3, 3-Blade Aluminum Prop #2011-085-09
Michigan Wheel Michigan Match 012032 Aluminum Boat Propeller
Quicksilver Black Diamond #QA3190R Aluminum Boat Propeller
or OEM
All are 8.5" Diameter, 9" Pitch
Solas Says,Reliability and Precision
SOLAS uses a state of the art squeeze casting process to make our aluminum propellers stronger and tougher than traditional die cast products.
As shown below, with 400x magnification of a propeller blade root cross-section, the squeeze cast propeller is almost non-porous, with finer grain size than the die cast propeller.
SOLAS aluminum propellers have 4 layers of paint. Using superior coatings and a high-tech painting process ensures excellent anti-corrosion performance.
SOLAS aluminum propellers are exposed to over 500 hours of testing in a salt water spray tank. This testing simulates more than 6 months of normal salt water use.
Traditional Rubber hub
Three blade aluminum propeller
Exclusive Solas squeeze casting process
Wide blade design specifically for 4-stroke engines
Outstanding acceleration and top speed
Michigan says, Michigan Match Aluminum Boat Propellers
Naval brass spindle
Rubber cushioned hub (Absorbs impact and the stress caused by shifting gears.)
Rubber bushing (Designed to spin free under significant impact, protecting you lower unit)
Costs less
100 years of propeller making experience
Limited lifetime warranty
It fits like your old prop.
It performs better than your old prop.
It costs less than your old prop.
And it's backed by a limited lifetime warranty.
Quicksilver says, Black Diamond Aluminum Boat Propellers
General purpose 3-blade aluminum propeller.
Inexpensive and easy to repair.
Recommended for speeds less than 50 MPH and applications less than 250 HP.
OEM which I can't find info on.
OEM and Michigan can be ordered here in Canada, Ottawa for the same price $97 +tax = $110 CAD.. Solas Can be ordered from down the street for $129 +tax = $146 CAD.
iboat, with tax and delivery has Michigan and Quicksilver for $104 and don't forget conversion from USD to CAD $125
o which one.. why can't i take a fan blade and put it on.
or OEM
Naval brass spindle
Costs less
