Diesel oil vs gasoline engine oil
Speakrdude
Ensign
I just went and picked up my single cylinder Diesel (Kubota EU300) block for my genset from the engine rebuilders. New Piston, sleeve, bearings, guides, whole 9 yards.
Anyway, I need to put oil in it. (all 1.4 quarts of it.) I have never owned a diesel engine before so I have no clue what kind of oil to buy.
I went to the local Oreily Auto store with the service manual in hand and asked for help with the oil. The manual calls for a 20, 30. 10w30 oil. The clerk suggested I use a regular gasoline engine "synthetic oil" and most all oils are above the diesel oil specs nowadays. I have my doubts before I ruin a $1000.00 rebuild.
Thoughts?
achris
More fish than mountain goat
Re: Diesel oil vs gasoline engine oil
DON'T put a synthetic oil in a brand new engine... You need a run-in oil...
As for running gas engine oil in a diesel... not a great idea.. Running diesel oil in a gas engine... no problem.
I read a thread in a motorcylce forum MANY years ago about oils... I'll hunt it down and post a link... REALLY informative... and well worth the read... (stay tuned....)
Ok.. the website doesn't exist anymore... Not surprised, it was 2005. I have it as a PDF. If you'd like a copy, PM me with your email address and I'll send it to you...
Chris......
haulnazz15
Lots of diesel guys use Rotella engine oil.
windsors03cobra
I would use a diesel oil, Chevron Delo, Castrol Tection, Mobil Delvac and Shell Rotella are names that come to mind.
Jeepster04
You can get a 4 quart jug of 30w Rotella at Walmart. Been thinking about using it in our boat engines from now on.
JustJason
use a nice quality 15w-40 and you have no problems.
Chris, if you have the pdf email it to me if you get a chance. i'll pm you the email.
rthomas
diesel oil for diesel, gas oil for gas,-its the additives that make the difference. diesel oil has different additives to help deal with soot and unburnt fuel, that is very important because soot can be very abrasive. I run chevron delo 400 in my work trucks
rbh
The diesel motors in our trucks take 15-40, the gensets take 30 weight in the summer and 15-40 in the winter.
D
DJ
Guest
Choose the viscosity your engine spec's. 30, 15W-40, etc.
The API classification should be: CJ-4.
j_martin
AFTER it's thoroughly broken in, you can extend the service life of the engine by running synthetic in it. Never run a synthetic oil in a new engine because it has such a good film strength that it can prevent the engine from wearing the parts that need to be worn for break in.
JRJ
Run what the manual says. I use Dello 400 in my Cummins.
pmat1
only difference with gas and diesel oils is that diesel oils have more cleaning additives. i would still reccomend diesel oil. and NOT synthetic until its broken in.
Bob_VT
Do not be surprised if the oil looks completely BLACK real fast (like after the first day)...... that is common with diesels.
Speakrdude
Ensign
How many hours are in a good break-in period to change the oil for that little guy?
642mx
Thats an old wives tale. Lots of engines have synthetic oil in them from the factory.
j_martin
And lots of engines are glazed over from not being broken in. It's a big deal with 2 cycle merc engines.
I don't claim to be an expert, but I do claim to be old.:D
John
D
DJ
Guest
That is terrific. But, you know what, us "old dudes" actually do know some things.
"Experience is the best teacher yet. "It takes 30 years to gain 30 years worth of knowledge".
But, I'm always open to new ideas. That's the difference between a dinosaur and a visionary.
skargo
Banned
Yep, I had a Vette that came with Mobil one synthetic in it.
Bob_VT
ALL the new Corvettes come equipped with synthetic oil ;)
gss036
SO, did my new Jetta and they do the maintenance for 3years using synthetic.
