Re: Diesel motor overheating
I'll play, for what's it worth, my 2cents worth.<br />Running between 2500 and 3200 RPM's is a big spread. If 3200 is balls to the wall, I'd cruise at 2900, tops.<br />Things to check.<br />Raw water-cooling.<br />Intake, starting under the boat if possible. Check for plastic bags or other obstructions. You should be able to feel cold water at your raw water intake, check out your sea strainer, and make sure water is moving. (Don’t mess with the fittings unless your sure there's a problem) look at your raw water intake valve. Chances are it didn't suddenly close, but make sure it's all the way open. It will probably be a gate or ball valve. If it's all rusted and nasty, it's time for dry-dock. I believe the raw water is cooling your exhaust. I would recommend a running engine check. Look for exhaust leaks around the exhaust manifold. Carbon deposits and hot air coming from your manifold and gasket bolt up. Put your hand on the face of your raw water pump, where the impeller plate is, and make sure it's cool. Make sure your exhaust risers aren't glowing red or melting. Then on to the fresh water heat exchange. Check the fluid, pop the petcock at the bottom and make sure its not sledge. Tighten hose clamps, again, watch it run, look for problems, belt driven pumps. If your fresh water was leaking, you would have to adding fluids. Feel for bad hoses. Check the oil lines to your turbo, I believe they are fairly high pressure and make a mess when they fail. If your turbo is going (from my limited experience) you'll hear it screaming and when it goes it will poor black smoke. Sounds fun, good luck.
