toberlindacher
- Jul 3, 2009
- 21
Hello,
I have a 1986 Invader OMC 4.3 I/O which I bought this year. When I first bought it, I was told it needed a new electric choke. At the time, the boat had problems starting cold but would throttle up fine and also run fine when in reverse but would die in neutral.
I have since replaced the electric choke and it now starts up just fine and idles in neutral just fine but dies about 70% of the time when I give it throttle. When it doesn't die it runs great. It also dies now when I put it in reverse. I have played with the idle screw but it didn't do anything. I have also run Sea Foam through it.
Any ideas what to look at? As always, I appreciate your help. I am at a loss as to where to look. Thank you.
Torin
Torin
