jschermesser1225
- May 13, 2016
- 2
1988 Merc 9.9 S/N - 0b364319....I bought this boat last year, and knew it had this issue. It would do just fine at idle speed and wot. And would within seconds die in mid throttle. Over the winter I rebuit the carb and the fuel pump. Replaced spark plugs. yadadada. Anyways put the boat on the water today, And I was hoping for the best. It started great like it always does, I idled around the lake going toward my dock. Got pretty close and decided to see if I fixed the mid throttle issue. It fell straight on its face. I can bring the engine out of a stall by shifting to neutral or tapping my choke will make it come alive for a couple of seconds. Took it out one more time to do some tests, and It seems to fall on its face anywhere above 10% throttle in gear, until I get to wot. And it will be just fine. I am so confused, it almost seems slightly intermittent. But I don't know, it seems worse now than it was last year. Im thinking its not enough fuel, because I can put the butterfly valve open and it will still die. It only does this in gear. Sitting in neutral I Can rev up and down no problem. Please help. When I told my wife it wasn't fixed It was as if I had stolen her candy bar. Anyways This is my first post. Im a diesel mechanic, Let me know where I should start. I have read a whole lot of different things about outboards falling on their face at wot, but nothing about mid throttle.
