I have a 1975 sterndrive Model 120 (140 hp) SN # 4159444.
The engine was starting up fine, but I did not see any hot water / steam exiting from the stern drive assembly, so I turned the engine off.
Thinking that maybe I could "prime the pump" (this may be the stupid part), I introduced water into the top of exhaust manifold by removing what seemed to be a sensor, and a L shaped brass fitting on the top. When I tried to start her up, it seemed to move for a fraction of a rotation, and then froze. All attempts to restart, such as using a parallel battery only result in solenoid clicks.
What an embarrassing way to take part in this forum ! Did I ruin the engine with some kind of hydraulic freeze ?
Thanks, mateys...
Thanks, mateys...
