did i kill water pump?
squarepants
I have a 350 chevy in a 1982 checkmate boat. I believe this is a stern drive unit. (new at boating) I started motor out of the water with no hose attached and ran motor less than 2 minutes. It now overheats when i try to use it in our local lake. What may have to be fixed or will it pull water up into engine when moving again thru water?
dhammann
Re: did i kill water pump?
You probably fried the pump impeller in the lower unit and are not getting water to the engine. Not too costly if you DIY
P.V.
No, there's no doubt, you DID fry your water pump!
squarepants
Thanks for your posts. This web site is great. Please keep the responses coming.
sea wolf
don't run it till u fix it. impellers are cheap, engines ain't.
stressR
It's Not a big job Get a book though<br />and follow directions.<br />you should know how anyway it should be done every year or two <br />good luck
mako
I was just wondering, why?
