Started my '97 115 after sitting for the winter, and it started right up, but it wasn't running on all cylinders. It was idling low and you could just hear that maybe one cylinder wasn't firing.
I shut it down, made sure all the the wires were on tight, and re-started, and it still wasn't hitting on all 4. I let it run for a couple minutes like that, and then I revved it up real quick for a second and it started running normally, you could hear it was running on all 4 after that, and it was idling at normal RPM.
I think one or two cylinders weren't getting fuel, maybe a float was stuck after sitting for the winter, and when I revved it up the carb cleared out or the float un stuck and it started supplying fuel.
Did I hurt a cylinder or two by running it dry for a few minutes, possibly without fuel/oil mix?
