I AM WORKING A 2001 90 HP YAMAHA 2 STROKE<br />THAT STALLS WHEN YOU PUT IT IN GEAR,<br />WENT THROUGH TESTS IN MANUAL, I AM DOWN TO<br />THE IGN CHARGE COIL. THERE IS NO VOLTAGE CHANGE <br />FROM CRANKING,IDLE OR 3500 RPM ON THE OUTPUT OF<br />THE CHARGE COIL. IT STAYS AT 5.3 VOLTS AC.<br />ANYONE HAVE ANY EXP WITH THIS SYSTEM ?
