Re: DHadley....Can you help?
Thanks guys for responding. I have removed the solenoid units from the lower unit and the brass plunger was broke close to the bottom, at the threaded portion. I purchased another used lower unit, but I couldn't get a reading (following the book) on the solenoids from the used lower unit. I have located used and new units, out of state, but these are really expensive. I'd like to be real sure weather the used units are bad.<br />I do know that there are at least two different types of solenoid units for the same 55hp motor. One unit can be disassembled, just as the manual says, I happen to have the one that can't. Unless someone knows how to remove the brass plunger from the upper solenoid's piston.(if that's what it's called)Then between the two units, I could reassemble a working unit.<br />Thanks for any help Folks
