Bulb stays soft. If I do not pump it, it will starve for fuel after a couple of minutes at high rpm. When I look at the fuel filter, it is 1/2 full of gas and 1/2 full of air. Pumping the bulb fills the filter. it will run for a while and then the same thing happens. It seems worse in rough seas. Bulb was replaced last year.Thanks
