Re: Determining Deadrise
Ken52,
I believe you described the rake [angle] of the transom, I think deadrise is measured from centerline to chine, transversely. I'm pretty sure deadrise is the angle that the bottom rises above the horizontal.
Transom rake, usually 10-15deg in outboard boats, and perhaps plumb or vertical [90deg] in some inboards, would be measured between the waterline and transom, in plane of the keel, and the square would be aligned fore and aft.
You can use a 'Speed Square' to mark your framing square for the degrees along the short blade. Then, using a level to create the flat plane, hold the framing square's long blade at the top of the level while it's touching the bottom center and the bubble is centered.
The angle of the deadrise could read on the vertical, short leg of the framing square 2' from the center, after the larger square were marked in degrees from the long tip back upward along the short blade. You'd have to use another straight edge to align the speed block's angles from the long blade's tip to the short blade's outer edge when marking the framing square in degrees.
cheers,
