depth finders
knarrman
when it comes to depth finders, i see they are mounted generally in the rear(on the transom)....how would this work while traveling if you want to see what's underneath the water in front of you?...also does anyone have any topography maps of the delaware river at easton pa and phillipsburg nj...and Assawoman bay off OC,MD??
Mahoney
Re: depth finders
Most consumer transducers aren't meant to side scan or look forward. Logically speaking this would totally throw off the depth as the distance looking forward is much greater depending on the angle than looking directly down. Also the sound waves will disipate more and not return back, giving you decreased sensitivity when locating the bottom.<br /><br />the readout on depthfinders is historical when they graph, so seeing a fish symbol above a bottom contour does not mean it is necessarily ther ein relation to the contour. it only looked to be there depending on which way the fish was going and the travel of your boat.<br /><br />while finding fish is a great feature of those fishfinders, finding echoes in relation to different structures and locating places more apt for fish to be is the real key.
stevens
Re: depth finders
If you really want to see ahead of the boat, I think there are really only two brands that will let you do that:<br /><br /> http://www.echopilot.com <br /><br /> http://www.interphase-tech.com/probe.htm <br /><br />However, I don't think these are as good at showing fish as they are at showing bottom structures, obstacles, reefs and such.<br /><br />
JB
Re: depth finders
Electronics topic.
