Re: Depth finder
agreed rabbit. I would also think that the molecular density is affected by salinity...<br /> <br />However, my point was that if the setting within the head unit for sound velocity is 1000 m/s and the actual sound velocity is 1500 m/s then then there will be a scale issue in depth readings which might show up in readings at different depths (maybe im wrong??). Not being sure of what settings EvinFla can change in his head unit - i used the term of sound velocity as in the end this will be a function of temp and salinity.<br /><br />You can't change the physics, but changing the equations that are used to express them can cause errors.
