Been working on restoring a boat. It already had a depth finder on it, but it has dual sensors. One for the back, and one that mounts on a trolling motor Im assuming up front. I cant get any trolling motors that mount on the bow because the clamps arn't wide enough. Its an old 65 lonestar so the edges around the bow are a couple inches to wide. First question regarding the trolling motor, would it be possible to take a couple pieces of 2by4 and put two lag bolts through it with nuts and washers on the back side that are wide enough to clamp to. And if that is not recommended if I hook the sensor onto the trolling motor and clamp it off the transom in the back how will that affect the results coming through my depth finder, seems like with the two sensors so close it would be redundant, and I might add I really dont want to mount the motor off the back!
