Dennis Moore's Manifolds
KaGee
Re: Dennis Moore's Manifolds
Bondo has a set of them on his little six banger. ;)
I Do,.....??.......
I thought I bought them from You, Kieth.......
thrasher
So are they any good? The people want to know!!:D
FreeBeeTony
I hope so............I just ordered a set...........spoke to the man myself!!
Ayuh,.......
Just posted My Opinion in a thread here somewhere.......
They seem to be a reasonably quality casting,....
The Fit,+ Finish were Good,.....
I preassembled them with the supplied Gaskets,+ Painted 'em.....
After a season,+ 1/2,.......
No Complaints at All.......
FreeBeeTony
Why did you paint them?
I was going to put a coat on the oiul pan while I can............what should i use?
KaGee
They only come with a base coat. I painted my OSCO's too. I used the hi-temp GM Blue from the auto store on all of my tin and the manifolds.
Ayuh,........
I used Rustolium Silver hammered finish,......
Because I already had it.......
And,......
They look Great with my Caterpillar Yellow 4.3.......
Ayuh,.................
thrasher
I hadn't appreciated how pretty my black engine was until I saw that!! I love red or black engines, but apparently Yellow isn't one of my preffered colours!!
Looks like a tidy install.. Don't mean to be rude, but yuch, I hope that yellow looks better on a bulldozer!! Sorry Bondo.
Did you install a remote oil filter? It looks to be in a comletely different position (front right of engine) to my 4.3L V6 mercruiser engine (rear left of engine)? Are you running an electric fuel pump as the oil filter location looks like it would prevent a mechanical fuel pump?
Gary
Ayuh,...........
That's the Fuel Filter,....
The Electric Fuelpump is mounted to the front of the Head, just above the Filter........
I happened to be painting Dozers,+ whatnot at the time I put that 1 together......
My next build will be Mack Bulldog Gold...................................;)
Olds Eddie
I understand that GLM is making his manifolds. I am running a couple of aluminum ones with IMCO stainless risers on my SBC 400 Powered fishin' boat. I really cannot tell if they helped but they weigh a lot less. I am turning a 14x23 prop at 60mph on a heavy hull and don't want to blow my Alpha apart.
KaGee
A little FYI... Dennis IS GLM. ;)
180shabah
Bond-O, I love the porta-pot in the first pic
thrasher, all of the later 4.3's run electric fuel pumps, GM removed the fuel pump boss, so there is no where to put a mechanical one.
