Re: Engine Accident Out of Water
Fifteen to twenty seconds of running isn't enough to get most motors hot enough to do damage. If you haven't changed the impeller in a couple of years, though, you should probably go ahead and change it now.
In my opinion, the usual position about running impellers dry for a few seconds is probably overtstated in most cases. With the impeller, just as with your pistons, heat is the enemy and the impeller isn't going to get very hot in 15 seconds either.
That said, running a motor dry is really unecessary so why do it? If you aren't sure that it is running well, the time to check on it is at home, not after you have loaded a bunch of stuff in the boat or tow vehicle, packed lunch and driven all the way to the launch. Check the motor in the driveway, with muffs on it. While your at it, check some of the other things that will be important for the day on the water. You don't have to go through an exhaustive list each time, but if you just check a couple of things, and rotate those items every time you go out, you get in a pattern which will make sure all of your gear is in good shape.
