Re: delete
Are you saying you poured antifreeze INTO the intake. Like, down the carb throat?<br /><br />If so, pull the plugs out, a lot of it will drain through the plug hole. Then crank the engine (plugs out) to clear the water from the cylinders. Mist some oil into the spark plug holes. Change the oil. Then go run it for a bit to dry the rest of the water out.<br /><br />If I missed something .. let me know.
