ParallaxBill
- Aug 27, 2006
- 341
Guys,
I know you northerners must put away your toys for the winter much earlier than most of us here in the south since in the piedmont of southern NC we usually don't get a hard freeze until January.
My boat is a 18' 73 Glassmaster Tarpon with a 165 L6 Mercruiser. It's engine box is well insulated so I was wondering if putting a light bulb in the box and covered up the openings near the transom with quilts/blankets etc. would be sufficient enough to protect against our mild overnight mini-freezes. I want to use the boat up until the start of the new year and figure this might be plenty safe for the engine up until that time. I would be sure to check regularly for unseasonal cold snaps that may be cold enough to do a quick block drain and whatever else might be necessary.
Your thoughts?
Your thoughts?
