decent color gps/chart plotter and depth
lime4x4
Which is a decent color gps chart plotter that will also shows you the depth of the area your in.
Pez Vela
Re: decent color gps/chart plotter and depth
A gps/chartplotter alone will pinpoint your location and, depending on the chart(s) installed, will provide historically recorded depth readings for "the area you are in." If you want real time water depths beneath your boat "right here - right now" you'll need a combination unit (multifunction display) with sonar capability and a transducer. All manufacturers make "decent" multifunction units. Learn what the specs mean, what specs you need for how and where you boat, and buy accordingly. Generally, you get what you pay for.
NYBo
When it comes to screen size, bigger is better, especially with combo units- you'll often be using split screen mode.
