decarb sprayed in one carb throat causes massive RPM increase
eli_lilly
Hello,
Now that the posts seem to be slowing down here, I can ask a couple of the questions I have had over the season. The first has to do with something that happened while I was performing my routine biannual decarb with a can of Power Tune that I had laying around (I usually use the Dunk method instead). When spraying it in three of the carb throats on my 87 Johnson 90, the RPMs dropped as I would expect. However, whenever I sprayed it in the starboard bottom throat, the RPMs would RACE. I am able to reproduce this consistently. I remember reading a long time ago on here that this indicates something, but I can't find the post and do not remember what it is.
Thanks in advance,
-E
JB
Re: decarb sprayed in one carb throat causes massive RPM increase
That carb is plugged up. The decarb stuff supplies the fuel the cylinder was starving for.
eli_lilly
Thanks JB, I'll take the carbs apart and clean them like I've read Joe Reeves describe!
-E
