Hi folks, I have a 89 70 Hp VRO that has given me some problems. Initially when i bought it the tach worked but I had problems with the engine cutting out. Has it in to check the harging system etc.etc. Turned out that the VRO pump was hooped so it was pulled. Engine runs fine alhough it seems a bit sluggish. Any way the problem is my Tach has not worked since. I have been trying to trace the wiring but it is tough because the wiring is hidden. I can't figure out where the tach wire should be connected to test. The manual is pretty weak on that sort of thing. So can anyone tell me where I should look and what colour "stock"wire i should be looking for?
