Dead on the water...
salister
Took the boat out today, changed the stuffing box so i was messing with that first, got it to about 10 drips a minute, maybe it should be less but I figured i run it a little and adjust it again. We wanted to wakeboard but the lake was crazy packed and it was a small lake so we cruised around a little. found a nowake cove and anchored, ate lunch and swam a little. They decided to get the tube out and got it ready, fired up the boat and off we go. one down kill the motor he swaps out for another rider, then fire her up and off we go. Next rider down and kill the motor, swap out a rider, new rider hops on the tube, go to fire her up. Nothing. No crank, no click, pop, backfire, burp, fart nothing. check the gear, shes in neutral, check my batteries, both on, accessories work fine. But no crank. tried smacking the starter solenoid with wrench, no go. Had to get a tow in... does this sound like a starter issue or an ignition issue. The guy I bought it from said it didn't run when he bought it, and he put a new ignition switch in it from a parts store and it fired right up. Im wondering if this is the cause or more of a starter/solenoid issue? my batteries are good. I really dont like the looks of a starter job on this thing any Ideas?:noidea:
92 Sanger FX22 direct drive ski boat, 350 mercruiser
Fired up great at home on the hose before we left. Fired up great each time I started it earlier today.
dubs283
sounds like your main ignition fuse is blown
have you checked the stickies section and read through the starter troubleshooting guide??
