Fester
- Mar 25, 2008
- 63
I have a 1985 Mercury 115 Inline 6 with tilt / trim. The lower portion of the block was submerged for 1 day 5 weeks before I bought it. The pistons move freely and I replaced the 2 tilt / trim solenoids and starter solenoid. Being new to fixing these I made a huge mistake and wired the battery to the same side of the solenoid as the starter motor. Huge spark to say the least. I installed all new wiring in the boat and a new ignition. I verified all is correct and the choke solenoid clicks when I push the key in on the ignition but nothing happens when I turn the key.
My main concern is that on top of all of the wiring at the console needing to be replaced I am fearing that the electrical on the motor is also shorted out. I am in need of some guidance as to what I can do to test certain things on the motor to determine what is wrong (stator, starter motor, trigger plate, switch box, etc.).
All of the wiring on the motor has been cleaned and replaced and all fuses have been checked and are OK. The only piece on the motor that I know that HAS to be replaced aside from a new starter solenoid (melted) is a small 1" X 1" black box with 4 little tabs coming out of it at the top of the block that looks like has some wires coming into it from the stator. Can anyone tell me what that is?
Sorry for running on but I want to know what I should test 1st on the motor with a volt / amp meter to see what is not working, fried out, etc. Any information would be helpful and if pictures are needed I can upload them. Let me know and Thanks in advance!
