dead cyl check
Status
Not open for further replies.
twisted039
so i pulled wires only bottom cyl had drop in rpms also no fuel burn on plug. but when i left the plug in the boot and cranked it it had spark<br />maybe a bad carb................?
Trent
Re: dead cyl check
You did not say what kind of engine? Anyway its time for a compression check first.
Trent
Re: dead cyl check
If compression is within 10 to 15 percent of each other and I had spark on all plug wires. Time to remove the carbs and clean with carb cleaner and install parts kits.
flashback
Re: dead cyl check
Trent, Guess you could'nt help your self. does a 65 eve sound like an I/O ? anyway if he has spark and comp. then its got to be the fuel those 2 cycles are just about bullet proof......
Status
