Re: damaged prop
You can check the run-out reasonably accurately yourself even if you don't have a dial indicator.  Take the prop off, put the nut back on.  Lower the drive and clamp a heavy steel "L" bracket (from Home Depot, etc.) to the anti-cavitation plate.  Screw a small "L" bracket at 90 degrees to the big bracket on the other end.  Now loosely clamp a stainless steel ruler or heavy piece of wire, etc.(the indicator) to the small "L" bracket and adjust it so the end of the "indicator" just touches the prop shaft at the prop nut end of the shaft and clamp it tight.  Now slowly rotate the prop shaft and observe if a gap develops or it gets tight.  If it gets tight readjust the "indicator" so that it just touches.  Keep rotating and adjusting until the indicator is positioned to touch the shaft only at the shafts maximum excursion off centerline towards the indicator.  Finally, rotate the shaft until the maximum gap develops.  Use a feeler gauge or sheets of notebook paper (approx. 0.004" per sheet) to measure the gap.  This gap will be the total run-out.  The run-out is half this.
