This is my first post here. I've poured over the threads to try to avoid asking the same question that's been answered elsewhere, but I'm not finding my issue.
The behaviour is this:
The motor (S/N B313046) had an overheating issue. I replaced the impeller and everything was good, however, a partial miss/stumble that the motor had been getting is now constant and I can't get rid of it. A few weeks ago the motor had great pull, lots of power from zero to full speed, especially at WOT. Today, the motor stumbles on takeoff, and only seems to run on all 6 cylinders when it's planed out and at WOT.
Diagnosis:
we've located the problem to be on cylinders 1 & 4. At idle, with muffs on, I can pull the plug wires on 1 & 4 and the engine tone doesn't change. 1&4 both have spark. Throughout the things we've done to isolate the problem, it has not changed cylinders - always 1 & 4.
What I've done:
swapped switchboxes
swapped coils
swapped/changed sparkplugs
cleaned the top carb (no kit, just took it apart and cleaned it. It looked great, one float was given a minor adjust)
squeezed primer bulb while running to check if it was fuel pump related
timing is 23 BTDC at cranking speed (if memory serves)
The missing on 1&4 has us stumped. We can't move the problem, and the only thing I'm slightly suspicious of is the trigger. I'm just about to check resistance on the trigger, but thought I'd post before I head out again.
Thanks in advance for any suggestions.
Diagnosis:
What I've done:
swapped switchboxes
swapped coils
