Cylinder tolerances
jb70508
I have a 1997 Johnson 115 Crossflow V-4 that had poor compression in two cylinders. I dissasembled the motor and found two broken rings in cylinders 2 and 4. There is no scoring at all on the cylinder walls. I measured the cylinders using a dial bore gauge and found that the # 2 and # 4 cylinder are slightly out of service limits. Cylinder two is .001 out of spec only in the middle of the cylinder near the exhaust ports. Cylinder # 4 is .002 out of spec at the top and middle of the cylinder. Is boring my only option, or should I just hone it and re-ring it? I have taken into consideration the .004 service limit stated in the manual. The .001 and .002 are in addition to the .004
ondarvr
You should be doing a complete rebuild, all new bearings, seals, pistons and rings, that means boring it oversized.
​The rings in these motors are known to be an issue, the other two are now a ticking time bomb, so since the labor is the same do it all now or you could be doing it again in 6 months.
jb70508
Ok, thanks for the reply. That is what I am going to do. Just found a machine shop that bores outboards. Will be dropping it off monday for oversized boring and ordering a rebuild kit as soon as he lets me know what size I need.
bob johnson
some people are on budgets and Id have thought hone all the cylinders and get new rings for all four holes and youd probably be fine!....clean up everything.... that's $200 less for not boring, and that's $400 less for using old pistons( assuming they didn't get damaged).... shipping...I bet youd save $1000 in all...... because who is going to bore and buy new pistons and rings and not get all new bearings as well.... if youre not dumping the bigger $bucks, then you reuse what you have for bearings... maybe you flip the motor in a year.......maybe you get 5 years out of it more!
if you start with a good regiment of decarbing regularly...it might not have any more issues
ondarvr
These old pistons don't respond well to new rings because the ring lands wear out and deform, this is one reason why they break, which they did. He also said the bores are out of round and out of spec, not a good candidate for a half hearted attempt at a rebuild.
jb70508
Which pistons would you recommend ondarvr? Should I go with forged or cast? Which brand do you prefer?
