Reel magic
- Oct 4, 2004
- 16
Guys if you have a 1995 200 salt water series carb engine and it loses a cylinder will the engine still idle smooth?smooth as idle the same rpm as the other in or out of gear?I have a pair of 1995 200 yamaha's Salt Water series engines.I have noticed lately that both crank up easy cold with 1 click of the electric choke idle at 7/8 in nuetral 550-600 in gear.But when I go to plain off with the binnacle controls being pushed evenly I have to give the port engine a little more throttle to get it up to the same rpm as the strd engine.Once up on plain its not as noticable they even out .But I have noticed that the port engine tends to lose rpm faster than the str like a 100 rpm drop at times in current etc.Could I be losing a cylinder?Or more of a ignition problem?I can tie the boat up to the dock and in neutral reeve up each engine different times and the strboard engine seams to be more crisper and quicker to the trhottle than the port?But if I was losing a cylinder shouldn t the engine lose rpm or idle rough? oir satll?at idle?<br />Thanks for any help
