Re: Cylinder head
If this boat is used for fishing in the aspect of trolling, you will get way more back by installing the BOYESEN reeds. It's the single best investment you can make for an engine that idles much. It improves startability, will actually allow you to lower your idle RPM 2-300, depending on model, and your mid-range response will also show gains. Top-end however, will be affected very little if any.<br /> The only time a BOYESEN will break is if you don't richen the idle circut as stated in the instructions. If a reed does break, there will be NO damage from ingestion as would be normal for ingesting a stainless steel reed.<br />If the engine is torn down, put'em in....you will never regret it.
