Cylinder Compression
1954jwt
I am about to purchase an 1988 Bayliner with a 85HP Force. The current owner is having the motor professionally tuned and compression checked before I purchase. I was wandering what should I expect the compression to be to feel safe in purchasing this boat? Thanks for your help. Jim T
roscoe
Re: Cylinder Compression
First off, YOU should have it checked.<br />Also have YOUR mechanic check the lower unit, the stator output, and the rectifier.<br />What good is it if he has it checked and lies to you about the results?<br /><br />Compression should be well over 100, preferably 120+ , on all cylinders. There should not be more than 10 pounds difference between the highest and lowest reading.<br /><br />The motor should be test DRIVEN, in the water, under a load, carrying the amount of weight you will carry in the future. That means you will probably need to put 3 friends and a full load of fuel in it to test drive it. Test drive should last atleast 15 minutes.<br /><br />Test running the motor in a tank, or with water muffs, is not an acceptable or reliable test.<br /><br />Make sure the power tilt and trim works, if equipped. They are hard to find and expensive to replace.
1954jwt
Roscoe, thanks for your suggestions. Have had motor checked, and the cylinders all check around 140 psi. His mechanic put a new prop, fuel pump, and new battery. I gave it a test drive with four grown adults, probaly around 700 lbs, and it ran great. Comes out of the hole with no problem. I brought it home with me and looking for years of fun. Again, Thanks for your help. This forum had made the difference. Jim
