cylinder #4 clean as a whistle
fisheymikey
I have a force 125 1988 on trophy 18.5
I have 140lbs on all cylinders
here is the problem, all 3 cylinders above are relatively dirty and the bottom one is very clean.
im assuming its due to the engine swap I made in the beginning they have used a silicone gasket.
also when I remove spark plug wir on any other cylinder I see a change to the engine except cylinder #4.
what do u think?
mike
Frank Acampora
Re: cylinder #4 clean as a whistle
Check for a leaking exhaust cover gasket or a leaking head gasket. Water will stem clean the sparkplug and also cause misfiring.
jerryjerry05
You have spark on all 4?
If not try swapping the coil leads.
Then the leads from the pack?
fisheymikey
yes I do have spark on #4
is there any way of checking the gaskets without removing the whole engine apart?
head gasket looks pretty simple the exhaust gasket seems I have to separate engine block from bottom part of unit
mike
fisheymikey
I also cant buy piece by piece I need to buy the whole gasket set for a whopping 200 bucks
where could I buy it piece buy piece im from quebec Canada
mike
jerryjerry05
boats . net I hate them but they ship to Can.
