Re: Cutting/drlling holes in Fiberglass
Don't wanna beat it into the ground, but check out the Craftsman All-in One Cutting Tool. It has a 5 amp 2-speed motor, and comes with a plunge router base and circle cutting attachment in a plastic case. All that for $59.99.<br /><br />It's great for cutting holes for stereo, VHF, speakers, and inspection ports, etc. Handy around the house, too. You can cut thru material up to an inch thick, and 95% of the dust ends up on the outside of the cut, not inside your console. Work slowly. Fiberglass really heats up the bits or saw blades. Dremels are weak, but good for detail work like polishing, etc.<br /><br />That coutersinking trick really works. Leaves a nice bedding area to compress sealant around the screws, too.<br /><br />One more thing. Your screws are probably stainless steel. If the screws start to bind up when you're running them in, STOP. Drill the hole a little larger. Stainless has a nasty habit of wringing off rather suddenly, and it's tough to remove the jammed piece.
