Greetings,
I need to replace the Cutlass Bearing on the boat I am restoring and am not sure whether I am doing it right. I have removed a grooved rubber liner from inside the housing and this came out fairly easily but there appears to be a sleeve of some other fibrous(?) material still inside the housing. Do I need to remove this as well or do I just buy a new rubber liner?
If I do have to remove the fibrous sleeve what would be the normal procedure for doing this considering the type of housing I have, which is only accessible from the rear?
Some pics below show the housing, sleeve and liner.
Thanks,
bluey.
Thanks,
bluey.
