pontoon chief
- Aug 9, 2004
- 116
I have a 1990 50 hp VRO Johnson that has been giving me fits.Runs fine at idle,but when it heats up under use it begins to run poorly,and will barely run.The water pump is not the most steller pump,but it does still pump,weak at best.I notice when this poor running starts the motor is very hot,yet no alarm sounds.<br />Does this motor have a high temp curcuit interrupter that will put the motor into a reduced RPM mode?
