Re: Crusader engines
Martien,<br />My boat is a 29' Phoenix Sportfisher. The boat weighs about 11,000 fully gassed up. When I bought the boat the motors were in stock 270 HP form. The boat performed very well, until the port motor swallowed a valve. With the old motors the top speed was 39 knots at 4000 RPMs and they cruised at 22 - 23 knots at 3200 RPMs. The boat got up on plane very quickly, but I never timed it. <br /><br />The current motors have been upgraded significantly. Vortec heads, Crane roller-lifter cam, .040" oversized 9.4:1 compression hypereutectic pistons, and more. I'm estimating about 320 horsepower with all of the torque available around 2500 RPMs. I kept the Quadrajet carbs because they have superior fuel economy at low RPM operation (trolling and partying).<br /><br />Top speed is 33 knots at 4400 RPMs, but I never go there. Cruise speed is 24 knots at 3200 RPMs.<br /><br />With the 1.91:1 reduction transmissions and the 17" x 17" props, the boat gets on plane in less than 5 seconds (honestly). So I'm real pleased with the performance of the motors since rebuild.<br /><br />The best source of info for rebuilding those engines is a good book on rebuilding small block Chevy engines, augmented by a book called "Small Block Chevy Marine Performance", by Dennis Moore.<br /><br />The transmissions are easy to rebuild if you are mechanically inclined and have a some experience. But you'll need a manual. However, the best manuals are the ones produced by Borg Warner years ago when they built the transmissions. Velvet Drives are now built by a company called Velvet Drive (really), and their manuals are not as good. I don't know where to find the old BW books, I borrowed from a friend, but the job is not impossible with the VD books. Just take a lot of photgraphs during dis-assembly. Try this site for transmission questions and to purchase manuals:<br /><br />
http://www.marinegears.com/techboard/index.html <br /><br />Also, if you bought the motors as a pair, one may be reverse-rotation. Is that true?<br /><br />That should be enough to you started. Again, beatifull work!!!<br /><br />mike
