Crossmember rotted out
tramsdell
Banned
Ive got a shore landr trailer with welded construction... the front crossmember is rotten through. I know how to cut and weld it properly but to save time i have a very similar trailer except that one is all clamped together, any issue with cutting out the whole crossmember and clamping in the other one?
GA_Boater
Clamped? I hope you mean bolted. :smile:
When one part of a trailer rusts through, other parts are on their way out, too. What is the condition of the rest of the trailer?
buy a new trailer, as GA indicated, the rest of the trailer is not far behind
tramsdell
Banned
Rest of the trailer is pretty good. That part must've held water at some point in history.
Saw that on a trailer last year.-------No drain hole in 3 of the dropped crossmembers.----What a shame when they cut corners like that
tramsdell
Banned
I suppose i should restate my question for more acurate responses. Is there any pratical difference in strength between a bolted ceossmember vs a welded crossmember?
yes. to do a proper bolted joint, you must take into consideration clamp force, torque and moment. bolted joints generally have backing plates or thicker members to take the localized bolt loading vs a welded joint can usually get by with a thinner base material.
how was the trailer designed..... continue on with that.
tramsdell
Banned
Fixed it. Built new bunks. Trailers good for another season or 2. Its kinda punky all around. I'll start shopping now.
