Re: Crossflow vs.Looper -Difference in metal?
Hi rodbolt.<br />Engine started to bog down on and off at WOT towards the end of last season and beginning of<br />this season. Suspected water in fuel- drained tank which did have quite a bit of water and installed a Racor fuel/water sep. That didn't help. Decided to check plugs and one looked very clean. Water was entering that cylinder. Compression in that cylinder was only 60psi (top left if facing front of engine) Others around 120-130 psi. Noticed head gasket<br />had slightly bent areas on metal rim with sort of a score mark near outer top edge of gasket.<br />Couple of small "dings" on head of piston.<br />Don't think it was detonation because the engine NEVER misfired. Ran very,very smooth.<br />Replaced gasket and the engine ran great for several weeks (compression went up to 80-90 after gasket replacement). This boat hit 6200 rpms so I don't think I had a problem with carb. Did note that she would stall more frequent than usual when I first started her up and put her in reverse. Anyway, on my final trip I heard a difference in the sound of the engine. Max at WOT<br />was 3000 then rpms. Next day checked compression<br />and that cylinder was 5 psi! Circumference of the piston looked chewed up along with cylinder head(area circling the dome). Suspected that a ring was on its way out and finally broke. Minor scoring in that cylinder. Haven't used the boat since because I don't want a bore job to turn in to a sleeve job. Looks like original small bore of 3.5" Never had a problem with the vro but will change over to newer version as a safegauard.<br />Always maintained engine, winterization, lower<br />unit drain, etc, plugs. I think it just came down to her time to be rebuilt. Thanks again for your interest. Happy Boating!
