Crossflow versus looper
Magnum1500
I run a 1984 Johnson 140 crossflow on a lightweight 15ft ski boat. What advantages does the loopcharged motor have over the crossflow?
JB
Re: Crossflow versus looper
Welcome to iboats, Magnum. :) <br /><br />More torque, less fuel usage, thinner bonnet.<br /><br />That's about it, unless you can be specific about what looper you mean.
Magnum1500
Would boat top speed be different crossflow vs looper if equally propped and everything else kept equal?
G DANE
There never were a 140 crossflow, prop rated horsepower. The old 140 was cranckshaft rated and is more like a 115. At wot, it should be horsepower to horsepower, but up thru the rpm range, the looper will have more torque and you will feel it like a bigger motor, what it actually is too, as the loopers have larger displacement combined with more effecient combustion too.
Magnum1500
Thanks,<br /><br />How do the weights of the 2 motors compare. I have heard that the crossflow was 30-40lbs lighter
G DANE
It is, go to napaguides.com, they list weight for different horsepower.
