Crossflow cylinder heads interchangeable?
bscappell
I have an 1982 115hp johnson that is salty. It has overheating issues and the heads have a lot of salt buildup and on one head 2 bolts that secure the water jacket snapped off. I have heads from a 1986 90hp Evinrude that are clean and used only in fresh water (plus that dont have sheared bolts!).
can i used the 90hp heads on the 115? They appear to be the same heads but I am in no way an expert. thanks!
interalian
There's a circular area near the top by a coil mount with the part number embossed. This pic shows part of it at the top left corner.
This one just above the top right head bolt.
bscappell
thanks, i found it. yes same numbers! appreciate the help.
leroy79
sent my 1980 evinrude 115 to the shop and they said it is the flywheel key so i went to the shop and gat a new one and put it on
and totque the flywheel to 110 lds. and it still wont fireup
interalian
Please start your own thread. Mods don't like hijacks.
