Re: Cross Reference Plugs
No direct links allowed....<br />dwnld the 2 Mb excel matrix<br /><br />I run the BPR6EFS in my 3.0L Merc, which crosses with the AC-MR43LTS which has a reach of 0.708".<br />The autolite #24's, and other plugs that I would think fit the standard Ford 302 head unless you have hi-volume heads, usually have a reach of 0.460". Or I might be thinking of chevy. But doublecheck to make sure you're running the correct length plug. Measure with a caliper if possible.<br /><br />Boomyal- there are some cross references on spark plugs, depending on how intelligent the parts counter guy is, where the reach is not the exact same. Sometimes a cross-ref can go to a slightly shorther plug, like from 0.460" to 0.375", in which case would definitely cause issues.
