This will be my first year/time wintering my tahoe q4 (merc cruise 3.0L) so I'm asking for critique of my plan for fear of missing something and causing damage to the boat/engine. I'm mechanically inclined and have the manual in hand but inputs from actual people who have done it is always nice.
A few questions though:
1. Tahoe seems to have made some kind of quick disconnects to drain the block? 2 blue tubes that can be lowered to the bilge to drain it out. Is that all that's needed to drain the block of water?
2. When purchased, the technician that went over the boat indicated that all we had to do was get some type of grease gun and pump through the grease and push out the old ones until you fresh grease. EZ-Lube spindle, could anyone point to this type of grease gun?
If you have constructive criticism, please feel free and links to iboats items are a plus as I plan to make one big purchase from here. (dealers around here rape on anything "marine")
Cliff notes:
Planned sequence:
1. Fill up with non-ethanol gas + stabil.
2. Wash boat/wax it.
3. Change engine Oil ( Merc filter + 4 qtz of oil?)
4. Change drive lube (i.e drain the lower unit and add in from the top reservoir?)
5. Fog the engine.
6. Pump grease thru trailer spindle til fresh grease comes out.
7. Cover w/ support, check tire pressure and put away for the winter.
Unsure items to buy:
types of engine oil, drive lub oil and trailer grease/gun
Thanks for looking over my list!
Cliff notes:
Planned sequence:
5. Fog the engine.
